You weren't watching hard enough Nick. :P
On Wednesday, we are heading to the Breakky Creek Hotel at 7pm for Dinner and Beer.
Generating interest from new members and looking at what we, as an organisation, can do to benefit our members more.
At present, we have happy laps and a few cruises but I'm sure we all would like a little more, so steak, beer and jovial banter to make 2013 awesome-sauce!
Wasn't looking hard enough, I was a highly focused watching machine. Or something like that lol. (I also scored a free shirt so little win for me)
Would love to come but with the hours I work its just not possible, I'm all for a few cruises through the year, even a cruise to some form of pub or something for lunch would be awesome :)
(unfortunately I can't drive my beast untill the middle of next year, due to still being on the pull me over plates and the fuzz not taking kindly to p platers with V8s powered imports :( )
Edited by Nikk_666
call me. if this is what I think it is about then I want back in.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
