I'm in a position were I've searched for 2 hrs now with no resault,
I need to know which afm wires to the ecu go to which map sensor
Eg does AFM ® which in the Nissan manual is pin 26(sig ground) and 27 (intake air signal) go to map sensor on port 3 or port 4? And which wire goes to which wire
Afm (nil) pin 34 (ground) and 35 (air sig)
® is afm closest to p/s reservoir this is by Nissan manual other afm is unnamed (lower)
I can't find a d-jetro instruction manual at all anywhere
My cars a r33 Gtr s3 I own all rb26 manuals so I got wire diagrams n shit but no apexi info and paulr33s site stopped updating info :(
Hope someone can help not getting a mech to do it I only trust myself on my car
Thanks guys
Ok thanks mate, there's one green one blue wire do they have a number or u can wire any of them to any afm sensor wire aslong as the vac line u put to the nipple corresponds to what afm wire you put to that sensor?
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
