Hey guys!
Okay so I've always loved r32 skylines, and as I'm getting a loan out to buy my second car I thought why not get something I love, I've already searched and found a potential buy.
Only problem is I don't know much about maintenance and if I don't do my research or facts right it would be a disaster! So just have a few questions for you guys, some help and knowledge would be amazing.
And yes these are probably the simplest questions but I thought I would ask or if there is a thread/topic on this site that could answer majority of them for me?
Anyways here are a few:
What type of oil should I use?
With the coolant should I keep using the same as the previous owner or drain the radiator and start again?
Servicing is done every 5000ks? And are there any major servicing or anything big I need to worry about doing if the previous owner hasn't?
These are just a couple going through my mind at the moment, sorry bout the newbie questions but I'd rather be safe then sorry.
https://www.sau.com.au/forums/topic/413142-new-to-imports-need-advice/
- short answer: if you drive like a granny - moderately priced ($40-60) off-the-shelf Castrol/Nulon/Mobil/Motul 5w-30/40, 10w-30/40
if you drive like a complete mongrel / enthusiastically - any decent higher tier oils ($60-100) like Castrol Edge, Mobil 1. Amsoil Signature range, Redline, Motul 8100/300V
oil thread - http://www.skylinesa...__fromsearch__1
flush out the old coolant and refill with Nissan's OEM pre-mixed coolant - around $50-60 - failing that any green coolant will do Nulon Long Life etc
make sure big things like timing belt, ancillary drive belts water pump, oil pump have been changed at least once if the car has more than 100,000kms
other normal service to look out for would be
engine oil / oil fiter every 5000kms
gearbox oil - every 30-50,000kms depending on how hard you are on it
coolant flush - 2 years or 50,000kms
fuel filter -every major service - 50,000 or 100,000 kms
brake fluid - 30-50,000kms depending on how hard you are on them (hard braking)
power steering fluid - every 100,000kms
depending on the mileage, and what you know about the car's history, being an older car i'd change the;
- engine oil / oil filter
- coolant
- gearbox / rear diff oil
- brake fluid
- fuel filter
- air filter
- power steering fluid
i've mentioned some places to buy/what to buy the above products if needed here;
hope this helps, welcome to the forum - post some pics of your car if you get a chance
all your answers can be found through a search...
mate, about as useless as tits on a bull, our search system for most accounts is crap to use and every one who joins might not be a a complete geek, and as we are always getting new members, they will benefit from these type of posts popping up
Edited by squareznboxez
squareznboxez you sir are a champion. now I hope I'm not stretching too far, but for example If I bought a new 34 (or 33, doesn't matter just an example), and wanted to get all that checked/changed, do you have a ballpark of how much it would cost?
I bought mine over a year ago now, R33 GTST, and had all my filters, oils, fluids, etc done, after i had bought it, it cost me roughly $700-$1000 dollars cant quite remember, without the receipt. I had receipts of the previous owner doing the oil pump, water pump, and timing belt. I didn't have to get that done, but the total of that was roughly $1000 on the receipt, but it also had a new radiator put in as-well. All up its fairly expensive get that done, but i does give you some peace of mind.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
