Hi all,
I'm selling my TS01 style rims, they are 17x10 in a multi nissan stud 4/5x114.3.
I'm unsure on the offset but gather they are approx +32 or +35.
Tyres are stuffed, no good.
Good condition, painted satin black.
Located in Adelaide, SA.
PM for further my number if interested.
Cheers, Matt
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
