Last chance to do some runs before SAU NATS
Post up if your going.
The weather forcast is looking good.
Wednesday 14 November
Summary partly-cloudy.png Min 15 Max 24 Partly cloudy.
Sydney area
Partly cloudy. Light winds becoming easterly 15 to 20 km/h during the day.
http://www.wsid.com.au/?m=events&a=event_page&id=150
Ill be there from around 1730.
Be there or be square.
https://www.sau.com.au/forums/topic/413227-wsid-14-november-2012/
On a side note the night is better off finished at 9 pm as the idiots doing burn outs on the return road leave bits of wire and other rubbish which can get stuck in or on your tyres, they do clean it up but from my experience (which isnt really alot) there is still crap left behind after them..
If you havent guessed I hate the rubbish cars that take up strip time and cover the return road in crap, the only good thing about them is the LOLS when they hit a wall.
Mark, what's this about monkeys throwing pooh on the return road?
People in a range of $200 shit boxs doing skids till the tyres blow, or the engines blow leaving oil and coolant down on the skid pan at the end of the return road, but do they stop there, hell no, they keep cooking them till the tyres come of the rims and leave debris and fluids everywhere.
The guys try and clean it up but bits of wire and shit from the tyres get stuck on the surface which then get stuck on my/everyones hot sticky tyres.
The monkeys get about half a hour to do this which eats into about 60 runs per lane.
So 120 people miss out on runs because 4 or 5 $200 cars want to impress the people with there awsesome skills at doing lame skids in crap old bombs.
As I stated before, the only highlight is when they hit a wall.
Anyways, if I get there early I usually get 5 or 6 runs in before its "STOP, MONKEY TIME"
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
