As topic states.
R33 gearbox fully rebuilt with PAR gearset 1-4 straight cut syncro engage. Gearbox built by Mr Transmissions and is less than 500km old. Have receipt for 5500k also in GTR bellhousing
NPC twin plate billet clutch and flywheel. The top of the line clutch that NPC has I believe. It's less than 100km old. Have receipt for 2500
I also have all the other parts of the manual conversion out of a VL if buyer wants them with sale or I'll sell them separately
The lot $6000 FIRM WILL NOT BUDGE
8000k worth of receipts all the gear is LIKE NEW
All the gear is inside the cAr and will be removed in one afternoon when there is a buyer. Car is not being driven so no more use on stuff then what I mentioned.
Everything is located in Brisbane but i am happy to freight at buyers expense.
Call or SMS 0412 169 376
Edited by UR LOSS
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
