The car is located at Nowra; which is 2 hours south of sydney and 2 hours east of Canberra.
Price is $10,000 ono
HSV SV120 (No 4 out of 30 made)
The car has the following as standard;
- 180KW
- 4 Speed auto
- SV wrap around seats
- Leather through out
- Plush velvet door trims with map pockets and leather inserts
- SV 16" alloys (walkinshaw rims, including the spare)
- Cold air induction
- LSD diff
- Exstractors
- HSV body kit
- Power windows
- Cruise controll
- Power aerial
- Trip Computer (functions include: over speed warning, Distance to empty, fuel used, K's travelled, time of travel).
- Delayed interior light / calais interior lights above back seats
- cental locking
- HSV leather clad sterring wheel
The car has 12 months rego on it. Has new door rubbers on all 4 doors. new carpet. new hood lining.
The car was resprayed 4 years ago in the factory colour (rose grey)
The car has travelled 198,000k's
The vehicle is regulary serviced ( last service at 195,000K's)
This vehicle is very enjoyable to drive, the exzaust makes enough noise so u can here it, but not loud enough to attract the wrong kind of attention nor be drowny and loud inside the cabin.
Call 0421582221
$10,000
For those of u who would like pic's; i do not have a digi camera.
How ever, Attached below is a picture of a SV120
PIC 1
PIC 2
Pic 3
https://www.sau.com.au/forums/topic/41345-fs-vn-hsv-sv120-5l-1-of-30-nsw-10000/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
