Hi Guys,
Just wanted to say a special thank you to the organizers and volunteers who helped make the weekend a great success.
Although I did not compete at Wakefield but went to watch on the Friday, there seemed to be plenty of track time with nice cars and well behaved drivers on board.
The Airport run was very well organized once the cold snap dissappeared lol, There seemed to be quite a few spectators turning out and we all had ample runs even though we probably shifted 3 ton of Blue Metal Gravel onto the grass. Some even tried to race the plane.
The Show & Shine was well represented and seemed to have a heavy flow of people coming an going, and great looking cars of all models.
Once again many thanks to the organizers
A job well done
Regards
Ray
dean31
Nissan Skyline GTS-R
https://www.sau.com.au/forums/topic/413972-sau-nationals-15th-18th/
Thanks for this Ray. I was meaning to post up a thread in our section and just haven't gotten around to it.
Hats off to Ash and Steve for all their long hours and dedication putting this together. They were the core duo that got the venues, sponsors and financial logistics sorted. I think everyone will agree that it's a premium event from start to finish. I'm proud to be a part of it. SteveO spent two crazy days as course marshal and burnt to a crisp! What a legend!
NSW handled the Wakie and Aiport event logistics for sign on, tech and conducting the day. Big thanks to Sean & Josh for assisting on tech inspection. Luke, Tats and Andrew for sign-on and general help all round at wakie and airport as well as our merch stand on Sunday. And of course thanks to Nick for making the trek to bring us the jackets cause we nearly sold out on the first day.
Huge thanks to SAU Vic for managing the show-n-shine. Again, was such a professional gig.
Most know I had my own dramas going on but was so great seeing the club atmosphere in its element. Lots of people helping each other, people borrowing tools or parts to keep running and lots of smiles and great people.
And when you look at the times from the top 1/3 of the entrants, well truly impressive! I was doing 1:11 which is normally top 1/3 but I think I was only about the mid way point! And of course we were still also open and accomodating for all the first timers too. Our club is so great for that!
Cheers to all that came to participate and/or watch.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
