Hi guys,
I've got a s2 r33 gts-t with a wheel scrubbing issue up front.
Components wise here's what I've got on there:
18 x 9.5 +38 with 15mm bolt on spacers (think this makes it effectively +23?)
Sydneykid bilstein/whiteline coilovers
245 wide tyres
Guards rolled
The scrubbing occurs when I hit a big bump, when I transition a lot of weight onto one wheel (high speed cornering) or say if I'm going downhill and turn hard and transition onto one side etc. I think from looking at the markings on the guards, that the main issue is because this wheel and tyre combo edge sits in line with the outer guard edge, so there's not a lot of travel distance needed to make contact and relatively soft suspension. Here are some pics of where the wheel sits and the markings:
I have thought about doing
Stiffer coilovers
Front camber arms/bush kit
Try fit thinner tyres on same rims
Thinner rims/thinner tyres
Is it possible with some combination of neg camber and smaller width tyres to fix this, or will I need to go to a smaller rim & tyre combo only?
Ideally I'd have an 18 x 8.5 +30 on there without the spacers, but this is the most expensive option, so I thought I'd ask some experts on here first if it's possible to work with what I have.
Cheers.
Edited by copycutter
I've got 18x9.5 +20 with a 235 tyre and lowered on my 33. I have fairly stiff suspension and no rubbing what so ever in hard high speed cornering and all. Maybe try and get the guards lipped and it might give u more clearance. It's fairly cheap. Maybe 50 a corner
Ditch the spacer, or you can go camber arms and add some negative camber (doesnt look like ur running much camber at all), just depends how much camber would be required, looks like 2.5-3 degrees may do the trick and isn't too crazy? Or lastly the most expensive option of thinner rims. My advice is ditch the spacers if possible (or get thinner spacers)
His guards are already rolled
lose the 15mm spacers, looks like theres 15mm odd of rim sticking out, just see how well the rim clears the suspension arms etc, on the inside of the arch
hahaha We msg'ed at the same time, The only option left is different rim with smaller offset.
What size are your brakes? how do 18" not clear the brakes?
Edited by badben
They're just stock brakes, but for some reason the +38's spokes design on the CR Kai means the spokes hit the edge of the brake caliper. I've tried 5mm slip ons - still fouls. It's just the shallow design that comes with that offset. I've got 9.5 +20's on the rear and I had to initially run them up front until I got the front spacers, and they cleared easily. I've never seen bolt on spacers in 7-8mm and I'm not real keen on slip ons, especially over 5mm.
The answer is as simple as it always has been.
Only use wheels that SUIT ALL ASPECTS OF THE FITMENT. That includes brake clearance.
No point having pretty wheels that make the little girls' pants fall off if you have to fit stupid spacers to make them work.
Depends on spoke design as we'll as offset. You will need to test fit the rims unless someone else on here has run those exact rims on there r33 and can advise. Cheap option, camber arms. Expensive option different rims
Going off your pic's, your car has good clearance around tyres, maybe suspensions to soft. Allowing to much travel.
Just so you know camber arms will make your tyres wear unevenly so you'll need to do regular tyre swaps, Front to back , left to right depending on if your tyres are directional or asymmetrical
Your guards don't look very rolled to me. Lose the inner splash guards. Failing that, I have posted this before. Works great, and it's free, just take your time.
http://www.skylinesaustralia.com/forums/topic/401848-trying-to-fit-my-dream-wheels-te37/page__st__20
yeah guard doesn't look very rolled to me at all
judging by where that scubbing mark is on whatever corner that under guard pic was taken you'd have no problem if they were rolled properly
also looks like you could do with dialing in some negative camber
Edited by mystery_kid
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
