  • 1 month later...
  • Replies 56
Ok, got a few additional parts for sale
RB26 Long engine (my old motor) 94 Model (has long nosed snout on crank)
Standard Bottom end (genuine 127,000km)
Gates racing timing belt (approx. 35,000km)
Gates racing adjustable cam gears (never dialed in) (approx. 35,000km)
Tomei Sump baffle plate (approx. 35,000km)
Tomei poncams (type A) 256deg lift 9.5 in and 260deg ex lift 9.5 (approx. 35,000km)
N1 Oil Pump (approx. 35,000km)
N1 Water Pump (approx. 35,000km)
Engine is in running condition (not compression tested), however a crack in the block was identified (35,000km ago) and immediately repaired by Gavin Wood Autotech.
Will come with red wrinkle finish cam covers, plug cover and timing cover (Trust clear timing cover is sold separately), the head off , block, diff and sump also included.
Will NOT come with Nismo oil filler cap, CAS, ignitor unit, nor oil dip stick
Asking $2,700 - off course I am happy to negotiate (maybe useful for someone that wants spare parts) - freight is at the buyers expense and engine is already out of the car
Direct Clutch Racing Twin Plate Clutch- also traveled 35,000km since installed and still got good meat left on the plates $500 Pull type clutch (will come with heavy duty fly wheel and slave cylinder)
CES Racing dump pipes - approx. 35,000km - $300
OEM - intake manifold - $250 I will wrinkle paint it in black too look like this
Denso / Sard 550cc injectors - $250 (will upload photo soon)
OEM fuel rail - $70 (will upload photo soon)
Projector type headlights (includes bulbs)
in excellent condition $500 (few marks only)
Trust clear timing cover - $50
Brand new Garrett turbo actuator set (from 2860r -5s) - $100
R32 GTR Cat back exhaust system (includes gutted catalytic converter) - few scratches on muffler $250 (cleaned and resprayed in VHT hi-temp paint)
OEM Front Pipes - $80 (will post photos soon)
R32 OEM FMIC - $150
Brand New 'RARE' Genuine N1 climate control assembly unit - perfect for someone who wants to convert from digital to manual i.e. removing a/c system - asking $480 (not sure on wiring i.e. if requires new loom)
Everything is o.n.o
Located on the Gold Coast
PM me or call me on 0404 006 580
thanks,
Anthony
Price drop!!
I no longer need these parts and are just taking up unnecessary space.
Asking $2,700 $2,200 - off course I am happy to negotiate (maybe useful for someone that wants spare parts) - freight is at the buyers expense and engine is already out of the car
Direct Clutch Racing Twin Plate Clutch- also traveled 35,000km since installed and still got good meat left on the plates $500 $350 Pull type clutch (will come with heavy duty fly wheel and slave cylinder)
OEM - intake manifold -$250 $225 I will wrinkle paint it in black too look like this
OEM fuel rail - $50(will upload photo soon)
in excellent condition $450 (few marks only)
OEM Front Pipes - $80 $60 (will post photos soon)
R32 OEM FMIC - $150
Brand New 'RARE' Genuine N1 climate control assembly unit - perfect for someone who wants to convert from digital to manual i.e. removing a/c system - asking $400 (not sure on wiring i.e. if requires new loom)
Everything is o.n.o
thanks,
Anthony
Edited by Ants
Also for sale are brand new Moonface Racing Rear Wiper Hole delete caps.
Have two available (as per photos) so be quick
$30 each
Postage is free anywhere
It will look like this on the car after your remove the unnecessary rear windscreen wiper and make the car look COOL :cool: - will fit 32, 33 and 34 skylines.
PM me if interested.
Cheers, Ants
Edited by Ants
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
