Ok guys, need som help please. I have a '98 Skyline GT RB25DE. It's been chewing a bit too much petrol and last week I ran out of petrol and ever since the car has been running really rough. I put some cleaner in it but has not improved it. It also seems to be smelling a lot like petrol. I would like to change the spark plugs to see if that improves it, I was going to put Iridiums in it but reading some of the posts, I'm not too sure now. Can someone please advise what would be a good spark plug without going over board with the price. Some say Spitfires are good, Opinions please!
https://www.sau.com.au/forums/topic/414152-spark-plugs/
What makes you think it's the spark plugs causing the problem? Have you tried simple things like resetting the ecu?
Maybe crap from the bottom of the tank got sucked up and clogged the injectors?
What "cleaner" did you use and how did you use it?
If you really want to change the spark plugs then personally I wouldn't bother with iridiums, especially if you are having problems, just put some normal coppers. NGK recommends PFR5G which looks like the platinums or BKR5EIX which are iridiums, in that case you can just go for BKR5ES which are normal coppers and go for around ~$4-5 ea.
If you don't know how to gap them correctly then just take it to a mechanic and get them to sort it out
Splitfire do make spark plugs, but whoever recommended it might have been talking about the coil packs not plugs
Edited by Serpandrew
https://www.sau.com.au/forums/topic/414152-spark-plugs/#findComment-6634644
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
