For sale is a brand new nismo fine spec engine.
Specifications-
- N1 Cylinder block
- N1 Component / nur spec pistons
- N1 Component precise friction piston rings
- Nur spec connecting rods (Balanced)
- Nismo F112 connecting rod bearings
- Nismo F112 main bearings
- Standard spec camshaft
- N1 water pump
- N1 oil pump
- Nismo timing belt
- Nismo metal head gasket (1.2mm)
- Nismo oil pan baffle plate
- Nismo fine spec 2009 special edition rocker cover ornament
- Exclusive fine spec 2009 special edition engine plate
- Front differential (Gear ratio 4.11)
- Black cylinder head covers
This engine is located in Perth WA and can be shipped anywhere in Australia at buyers exspense. I am asking $15000.00 ono for the engine. This is a rare piece of nismo excellence.
Other parts i have for sale include:
Brand new Midori titanium front pipes for GTR : $1100
Brand new HPI dump pipes to suit GTR: $695
Brand new genuine N1 bonnet lip to suit GTR: $285
6 used ignition coil packs to suit RB26: $250
These are in perfect working order,selling due to fitting splitfire coils i had.
Used Field boxer series 2 Electronic torque split controller: $250
I wil try to answer all enquiries as soon as possible.
Edited by RBrocket
  • Replies 43
Expected power of the engine with supporting mods?
It depends on the sort of mods you have in mind. My thoughts were, camshafts ,adjustable gears, 650-700hp turbos,injectors to suit,nismo plenum,after market ecu. etc. probably 550-600hp at flywheel. This engine is a good base to start with, and it really depends on what you want to do and spend.
Will the Midori front pipe suit a r33 Gtr?
What diameter?
Thanks
The midori front pipe will fit and R33 GTR. The leading pipe is 75mm id,the second pipe is 70mm id and the exit pipe is 90mm id. Midori say the difference in diameter between front and rear turbo pipe is to optimise turbo flow. This is a neat and highly crafted set of pipes.
How negotiable on engine?
A standard genuine nissan RB26 long engine from Just Jap is priced at $12999, and a R34 RB26N1 genuine nissan long engine for $14999,they also advertise a fine spec engine the same as this one for $24999. I put ono on the post so throw me an offer. You never know.
Specifications-
- N1 Cylinder block
- N1 water pump
- N1 oil pump
- Nismo timing belt
I will try to answer all enquiries as soon as possible.
For those who would like to contact me direct can do so on 0427620003
Another price adjustment:
HPI Dump pipes now $650. This is good value
N1 Bonnet lip suit R33 gtr now $250. Good value
Coil packs suit Rb 26 now $ 150. These coil packs are fine.
Field torque split controller now $200.
Price adjustment:
Nismo engine now $14000
Coil packs $100
Torque split controller $150
Bonnet lip $250, these retail for $998 from Nissan.
Edited by RBrocket
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
