Have a set of these in immaculate condition. Great for track days as they are lightweight and forged made by rays engineering.
19x8 +30
19x8.5 +33
No gutter rash at all. Comes with the Infiniti center caps. Fits sedans very nicely.
Pick up Brisbane South $1K wheels only. If require postage please pm postcode
https://www.sau.com.au/forums/topic/414611-19-rays-coupe-wheels/
that's becoz Jon is an Accredited Wheel Whore of SAU who keeps updating his wheel style every 6 months....one of the best V35 sedan owned...good job Jon...wud be nice to meet up and have a closer look at your new wheels....
Lol Thanks Shiva. Will post some better pics when I have the opportunity to take some better ones. I bought these Rays wheels in this unmarked condition and only had them on for around 2 months while waiting for my new wheels to arrive, so yeah they have not been repaired or repainted as far as I can tell. There are some very minor stone chips from everyday driving but apart from that they are in almost showroom condition. And yes quite rare. $1K for a set of 19" forged wheels made by Rays that look good are hard to come by! :)
Depends on your definition of perfect. These wheels were made for the Coupe, so yes they are perfect for it ie: sit within the guards, legal no guard rolling required etc...
However if your definition of perfect meaning flush on the guards and have some poke then no.
Plenty of photo examples here on how they sit.
http://www.google.com.au/search?hl=en&q=v35+coupe+wheels&bav=on.2,or.r_gc.r_pw.r_qf.&bpcl=38897761&biw=1440&bih=813&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&tab=wi&ei=xrq2UOX7HuaRiQeGqYCYAw#um=1&hl=en&tbo=d&tbm=isch&sa=1&q=v35+19%22+rays+coupe+wheels&oq=v35+19%22+rays+coupe+wheels&gs_l=img.3...12900.13403.2.13671.5.5.0.0.0.2.217.599.0j1j2.3.0...0.0...1c.1.gsZ6qa06I4w&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.&fp=f6682e0171045f89&bpcl=38897761&biw=1440&bih=813
  • 5 weeks later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
