T3/T04E Ball bearing turbo. Similar specs to GT25/30. . T3 Turbine , turbine wheel stage 3, A/R .63 for fast spooling matched with low back pressure, std T3 flange. Exducer diameter 2.25" Compressor A/R .50, 57 trim, 3" polished and bell mouthed inlet for higher flow and less turbulence for cooler air. 2" outlet, scroll internal deburred and detailed. Flows 45lb/min max. Ball race for the quickest spool and to reduce load on thrust bearing. Internal or external wastegate. Oil cooled. 1/8 NPT or std 2 bolt oil inlet. This turbo will suit from 1.8L + , Honda, Nissan, Holden, Falcon, Saab, etc. Awesome performance matched with reliability. Will run 30lb boost and support 500+ HP. This is not a rebuilt unit, it is 99% new(has been used in my gtr for two days as i think i still like twin turbos better so i am going to buy two hks t25/30 , but the cost is less than most rebuilt turbos.
Hks air filter used but it's brand new coz i bought it to fit on my car but i can't find the adaptor for it so ....selling for 100 only
Blitz Boost Gauge brand new read in bar $ 200
i am looking for $1400
but still be welcome to make me offers
i want quick sale
if buy 3 items at the time then i will take 1600 for 3 items
  • 3 weeks later...
  • 8 months later...
Closed
Rallyart: You were pm'd about your trading here and informed that you are required to make a contribution before you can continue to post and you failed to reply.
Either make a contribution and register as a business trader or do not start another thread in the classifieds.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
