well it just needs a main power supply and i'd say it should just T off the circuit board on the dash aka the dash plugs for a31/c33 should be the same and the cluster does the extra wiring work
just dont blame me if it doesnt work :P
the circuit board for the clock has terminals where it screws onto the cefiro cluster.
One screw acts as a positive, the other as negative
It's live at all times, and a separate light on the cluster itself illuminates the clock.
Just buy a Cefiro cluster and smash it in.
I kept my clock. Boost gauge didn't quiet fit :(
my original 88' tacho goes to 8K rpms my other one goes to 9k so that might help, although they're still interchangeable for ceffys, not sure why theres a difference with laurels?
