Nothing yet, had 5 different auto electricians come to my mechanic and none of them know, dont wanna know since its an import. Been to busy at work to chase this up christmas rush is killing us. Only update now is engine light wont turn on fuel tank doesnt prime so no spark at all. Gonna do a search now for stagea electric info and english version for the fuse box.
That sounds like ur losing 12v to the ecu when cranking, if ur ecu isn't getting power then u won't get the fuel pump to prime, u'll get no spark or injector pulse.
Yeah computer died, tuner replaced it and car started straight away but he reckons what your saying something shorting it and it may happen again. Any ideas on what to directly check for as cpu is now not covered by warranty if this happens again
Glad to see u got ur car going again, as for what's causing it there are many possibilities, bad earth is a common cause of things shorting out, broken wires, have u done anything electrical to the car lately? Install something ,remove something? Make sure that the connection to the computer is on properly and the bolt done up, check all connector to igniter,coils may ect. Make sure battery terminals are tight and in good order. Also make sure u have the correct fuse amp fuses in the fuse box, someone may have put a higher amp fuse in there cause they had nothing else, if my memory serves me correctly its 10a for the ecu. Good luck with it, hope for ur sake it don't happen again. Where bouts u located?
Sydney. Nah the only thing electrical done to the car was get tuner to put ecu with nistune map on it and z32 afm. My original computer is now back on with the same nistune map installed and same tune, cas was also swapped as that was burnt out. Car is running really well now just picked it up and took it for a quick spin. Will look over everything shortly and make sure nothing else is loose, it has been looked over though quite a few times. Thanks for all the help
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
