Hi guys,
more moving to free up some space and $$
motor has only seen 50kms....bought it off a mate that needed money desperately...
well over $15K to replicate
1. CP Pistons 86.5mm
2. ARGO forged rods (23mm gudgeon pin)
3. Nitto Metalhead gasket and crank collar
4. Pro engine 4WD adaptor
5. Trust extended sump with ATI FRONT DIFF
6. TOMEI oil pump with modification for additional external pickup
7. Prepped concrete block, Prepped crank machine balance etc...
8. 1/2 inch ARP headstuds
9. ATI 1000hp balancer
This is a motor that i would have no hesitations using as is (without stripping down)
$9.5K
Cheers
Steve
I have received a few pm'z in regards to splitting ext bits to the short block....
1. Tomei oil pump
2. Ati balancer
3. Sump with front diff
I will consider if there is enough interest but not at this stage... Pm offer and contact number so i can keep order and track :cheers:
Any info on the ATI front diff?
LSD?
Tried Googling but couldn't find any info on ATI doing anything other than gear sets for Ford diffs!
What sort of money you chasing for it...?
for? if sump alone? then i'm not sure.... pm with a offer and i ill have to work out whether its worth parting the package out.
(there is a final number i wish to get for everything)... probably have individual prices for everything in a few weeks.
thanks
Lmao
before making a $600 offer for the sump
This is how much it would cost you to do yourself
Used sump $250
Trust extension $450
Remove diff to weld $50
Weld $400
Ats front diff $1850
Install diff $250
Oil $100
Now think If you wanted to sell this how much would you offer?
:P
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
