i have stuff in my garage i need to clear out all prices below does not include shipping but pick ups are welcome, parts located in newcastle area
stock r34 gtt turbo with OP6 housing $400 ono
stock r34 gtt SMIC $50
HKS BOV + piping $120
stock coil packs don't know which is faulty $10
orange side indicators one of them has a broken clip $5
orange front indicators $10
stock gear shifter with stock gear knob $20
r34 get grooved & dimpled rotor front and rear never been used or fitted $680
EBC redstuff brake pads front and rear $400
all prices are ono so make me an offer, i prefer pick up but willing to ship at buyers cost
https://www.sau.com.au/forums/topic/415107-garage-clear-out/
if that turbo was hiflowed i would have driven to you lol
actually it was taken out and replaced with a highflowed one.. i bought one just like it online and sent it to get it high flowed... the only reason i did that so i can still use my car while the turbo is getting high flowed
i'm trying to upload some photos but i cant seem to figure out how,, so if anyone whats photos text me on 0468323234 and i'll send you some pics
guys seriously i need the stuff gone make reasonable offers and i promise you wont be disappointed
stock r34 gtt turbo with OP6 housing $400 $300 ono
stock r34 gtt SMIC $50 SOLD
HKS BOV + piping $120 SOLD BUT STILL HAVE THE PIPING $20
r34 RDA grooved & dimpled rotor front and rear never been used or fitted $680 $550
EBC redstuff brake pads front and rear $40 $300
prices are still negotiable text me on 0468323234 for pics
stock r34 gtt turbo with OP6 housing $400 $300 ono $250 the turbo has about 80k km very good for high flow
r34 RDA grooved & dimpled rotor front and rear never been used or fitted $680 $550 $500
EBC redstuff brake pads front and rear $40$300 $250
stock Ecu $100 ono $90
Apexi power intake filter $60
HKS filter $20
prices are still very very negotiable
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
