post-82304-0-53490000-1354955886_thumb.jpgpost-82304-0-46714000-1354955790_thumb.jpgpost-82304-0-67853400-1354955808_thumb.jpgpost-82304-0-86291300-1354955818_thumb.jpgpost-82304-0-81748700-1354955835_thumb.jpgpost-82304-0-32431400-1354955853_thumb.jpgpost-82304-0-71827000-1354955868_thumb.jpgFor sale due to lack of work where I live so I have had to move to the city where I cannot keep 2 cars on the street as parking is very expensive and I need my Van for work so I have to get rid of my beloved series 2 S14.
It's registered till the 7th of May 2013.
It's a 1996 series 2 S14 luxury. (It has a sunroof and whatnot)
The car is pretty much standard other than;
Exhaust 3 inch whole way through,
Front mount,
Tein Superstreet coilovers,
High flowed T04 Turbo running roughly 1 Bar of boost,
Remapped standard computer,
Touchscreen DVD player,
Oil catch can (Baffled),
Serviced (200 kms / 3 months ago)
Car was repainted probably 4 months ago,
Stainless Manifold,
Hardrace Adjustable castor rods (installed about 500kms ago)
New tie rod ends (Installed same time)
New continental tyres on rears (S14 stockies)
Front tyres not too bad (S15 stockies)
Comes with Apexi turbo timer (Not installed but new in box)
Not a cracked dash but a split in the leather, Passanger window tint is pretty crap too and theres a tiny stone chip in the rear bar.
There's probably more but I can't think of it right now.
The car is located in Camperdown Sydney, Will be happy to drive to you as long as I don't think you're a joyriding Tyrekicker.
DO NOT CONTACT AND OFFER ME 7 OR 8 THOUSAND I WILL NOT ACCEPT IT.
Any questions call or text Eric on 0410300281 If i don't answer text me and I'll call you back! No private numbers! Price is $10000
  • 1 month later...
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
