Hey all
I was pulling the clutch out the car on the weekend on a hoist and saw one of the turbos ( -5s ) were leaking from the rear on my 33 gtr
I havent noticed any smoke or anything, and it isnt leaking to bad.
The leak is coming from the rear of the turbo.
Is it a simple fix of removing the turbo and changing the rear seal over?
Where can i get it from etc?
https://www.sau.com.au/forums/topic/415294-turbo-leak/
Its always the lower turbos that has issues on the GTRs. mainly because there isn't enough room left for the drain. See if the turbo has abnormal amount of shaft play, if not check and make sure drain pipe is kinked, blocked or siliconed all over.
If its been like that for a while and you've been driving it then it will need new seals.
https://www.sau.com.au/forums/topic/415294-turbo-leak/#findComment-6661982
It will more than likely be blowby oil, pull the intake off the turbo, clean it out (nearly all ofthem have oil in there)
Install an Autech style catch can to help prevent it from happening again,
You may also have to clean the cooler out
https://www.sau.com.au/forums/topic/415294-turbo-leak/#findComment-6662630
Hey DVs what's the best way to clean out intercooler? Honest question think this might have been half my issue with decreasing power I get a bit of blow by though
https://www.sau.com.au/forums/topic/415294-turbo-leak/#findComment-6663952
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
