i currently have bilstein coilovers on my V35 but am thinking about changing to something a little more aggressive for track work. just wondering i there are any coilovers that could be recommended by those of you with some track experience (not bc,killerB,or any eBay specials)
i have been considering Aragosta TypeS, JIC FLT-TAR, Zeal FunctionX.most running 12kg/mm front and 10kg/mm rear springs.
Also would be doing bushings at the same time,can anyone comment on SuperPro and Nismo bushings?
https://www.sau.com.au/forums/topic/415453-cpv35-suspension-track-setup/
You must have a sizeable bank account to be quoting on aragosta's. If you're not happy with your billies then aragosta or ohlins are your only real upgrades.....
Bilstiens are pretty awesome - so it's surprising you're unhappy - or is it just that you want a stiffer setup? If that's the case, you should just get them rebuilt with custom valving - that's the beauty of Bilstiens. Shops like Fulcrum can turn your Bilstiens into what ever you want them to be.
I would suggest signing up to zclub.com.au and asking the question there. Those guys far more regularly track their cars, and given the suspension is the same I reckon you'll get better answers backed by experience there. I know for example there is a guy on there (MR RIZK) that has just sold his PSS10's for Ohlins. I reckon asking him your question would get you all the answers you need.
cheers
Mat
Why wouldn't you consider BC BR series coils? They'd do the job, unless of course your car is running a lot of power and do series track work..
As for bushes, i have used factory revised bushes for both my compression rod bushes and haven't had any problems yet and it's been about 5000km. I would recommend Whiteline or Superpro for control arm etc..
thanks forthe replies guys. definitey agree a set of s tyres will make the biggest difference in lap time-my lap times at mallala in my integra dropped from high 1:26s on street tyres to low 1:23s on RE55s.
stil i am considering changing the coilovers too.just waiting on a few quotes..so there might be a set of Bilstein coilovers up for sale soon :)
  • 1 month later...
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
