Guys
Really can't find anything on this...
Will a 300 x 22 *EDITED* rotor fit straight up with BNR34 calipers??
These are going onto a BNR32 on the REAR...
If not, what is the biggest size rotor that will fit straight on (dust covers will need to be removed I know)??
Any other info appreciated!
Edited by $$slowmedown
The factory sizing for GTR brembos are front 324x30 and rear 300x22 the calipers are designed to have that size rotor, from everything ive read the only problem with fitting them onto a skyline or silvia is the R34 (gold brembos) use a 14mm bolt so the hubs have to be drilled from 12mm to 14mm to fit them. I put a set of 33gtr brembos on my s15 and had no issues with rotor size I just used the oem sized rotor.
Cheers Seb
I fkd up and have edited now. I meant 300 x 22 for the REARS. Apologies
Yes, read all about the thread problem with fronts but the REARS are never mentioned!!
Just wanted to CONFIRM with someone who has actually done it that they bolt straight up with rotor size above...?
There are several threads about this. The bolts on the Brembos are a dfferent pitch from the Nissan ones 1.5mm instead of 1.25mm. The backing plates will need trimming/removing (but be aware of the prximity of the upper outer sustension link to the rotor) and I had some new lines made up as I was not happy with the ones that came with the callipers.
See this thread for other stuff:
What Size Bolts Are Required For 34 Gtr Brembo's?
Thanks mate. Yep, read through other threads but none mention the REAR rotors...
I am trying to confirm that 300 x 22 rotors are the correct size to be using with this setup on BNR32
Cheers
Cheers
Well that one does.
There are only two sizes for use with the Brembo calliper at the rear and only one at the front. The larger of the two rears is the R34 V-spec II NUR N1 fkn blah size which arent common anyway.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
