I'm a Richard Dean Anderson? :D
Damn site is being a PITA and won't let me post a pic so I'll slap up a biggen courtesy of Photobucket.
Shame about your dash Richard. Coulda made a mad mantelpiece, shelf or even a cockpit for Gran Turismo Playstation Fun!
Cheers Fella.
Thinking next thing I will do is cut out the floor pan under my accelerator pedal so I can put my foot down further. :laugh:
Moarrr powahhh is moarrr...
but seriously, got some paint stripping to do on my rims. Paint the centers Black? maybe leave them the silver that will be revealed beneath the uneven goldish crudd.
whats happening on Sunday.
some scratched the paint off my bumper sort of like sand paper a few marks about seven of them. Now i wonder if i can get anyone to colour match my paint? Any ideas.
Sunday? Cruise to Goulburn to meet with SAU New South Walers. You wanna come with? Events Link --------->>> http://www.skylinesaustralia.com/forums/topic/418972-mid-march-mid-way-meet-up/
Bugger about your paint. If you wanna DIY then go to Capital Auto Paints in Fyshwick and they can match your paint in a Rattle can. :yes:
OT... Hit 2 of my rims with paint stripper. Under the gold is silver, under the silver is white primer, under the primer is silver. Bitch of a job, hard n Sweaty :sweat: but it will be worth it. :D
Saw that but did not think it's this week the days are going really fast for me. Enjoy anyways it will be a good cruise
$3k to do ECU, with all sensors and shiz ready for e85 when i can be bothered.... another like 400 or so to do cam gears. Let saving commence!
Do your cam gears first and dial them. small outlay for gains :)
$3k on ECU FTW.
Look around dude, perhaps 2nd hand Haltech Pro for around $1400. Spose the full tune is all the extar mullah huh?
Oh and washed da car today
$3k on ECU FTW.
last i saw, powertune had the 32/33 platinum pro(haltech) plug in for around 16-1700, brand spankers.
look around, you may find it cheaper.
decent pricing to be had at the moment.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
