  • Replies 61
I'm up for a few games of pool - I used to be quite good, and had a habbit of cleaning up the table, sinking several balls in a row (which BTW earned me the nickname: Demon Dave :mad:)
but in retrospect it was probably more luck than anything else. :)
I haven't played in years though...never even seen a table in Japan!
They better have the mix nuts.
Yeah, they better! What kind of pool hall runs out of mixed nuts??? Jeez...
Btw, we went to a pool hall in Nishinomiya somewhere, and parked at a "24 Times" parking lot, where we happened upon this:
Z10 Nissan Cube, completely standard apart from those stickers... :headspin:
Yeah Kei-cars or tallboy wagons seem to like a mild dose of sticker-tune. My neighbour's black 98 turbo Move used to have a HKS sticker on the back window and other various sticker-tune...but I don't say much because he gives me free window wiper blades, coolant, etc from work (aftermarket/OEM parts supplier to makers). He's also a nice guy who is still saving to buy a nice car, being young and married ain't easy.
Also Justin will attempt again this Friday to prove his ghey shots will win over my powershots...I will have some photo evidence where possible :rolleyes:
Also Justin will attempt again this Friday to prove his ghey shots will win over my powershots...I will have some photo evidence where possible :D
Yeah.. ok. But this time I'll have a team of Japanese girlies cheering me on ;)
Justin how you getting there tomorrow? If your not riding with me, meet at the pool place just after 9pm.
Hankyu Nishinomiya stn, North Exit, keep walking North along the street. You should see the 7-11 on the corner if you remember, and MOS burger is to your left on that coner over a block. Keep walking North another 10 metres and the pool place is to your Right, up the stairs.
:rofl:
Troy for some reason, when I read those directions they sounded just like all the other directions I've ever been given in Japan...
leave this station, go along this street, turn right when you get to a seven eleven...
just re-affirms that once you've been to one Japanese city, you've been to 'em all. :( In actual fact I can picture a place here in Yamanashi that has a similar layout - MOS buger, 7-11 and a (swimming) pool :)
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
    • Depending on the hose, sometimes engine out is the easiest option
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
