give BEL Garage a call, if I remember correctly they have some SARD regulators in stock for less than that. tell them KJ sent ya heheh. 02 9763 7022 or www.belgarage.com.au
anyway, in my own experience, SARD regulator + std injectors + R33 GTR VSpec fuel pump with std turbo on RB20 - after extensive tuning with AP PFC, std injectors were maxed out, had to run higher pressure via regulator. Don't like doing that, and with recent turbo upgrade, bought a set of 550cc injectors. had to buy the GTR resistor pack too, as PFC requires std impedence. Couldn't be bothered waiting for parts to arrive locally, paid almost $1.4k locally - not that bad for local price actually. Ah well, bizs have to make money, and I couldn't wait :mad:
  • 3 weeks later...
lukits01: did a little search and found this out.
Q1. SARD have a few different type of FPR's, but they come in 2 sizes only (i think). That would be dia.50mm x 96mm and dia.66mm x 92mm.
Q2. dunno
Q3. I don't think the SARD FPR's bolt up to the standard rail, but i did see adaptors for them so maybe they do?
-rb25
yeah you need the adaptor for nissan fuel rails.
you can choose the fittings to go with whatever SARD regulator you choose.
you will have to get the adaptor for the nissan rail regardless.
they are super easy to install.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
