Help With Starting R32 Gtr? Anyone Got Consult/etalk And Can Help Me Dx My R32 Gtr
I cant get the damn car to produce spark. Everything else seems to be working.
And I've lost my consult cable in the move. And the software.
If anyone has something they can lend or a spare half hour with me, please PM me.
I'm at my effin wits end.
I'm in Latham, Belconnen.
I also have a borescope Im happy to cart around and help people dx their engine, fits easily inside the spark plugs. I have 50 thou oversize pistons, I read the markings :) Just wish I could find that 12mm socket I dropped under the plenum - didnt fall out and Im buggered if I can find it.
sorry mate - I dont have one.
What have you checked so far that may be prohibiting spark ?
Fuses - especially main fuse in engine bay. Resistors ?
Ignitor - swap over with a known good one. Make certain it is grounded.
ECU
Battery - how dead is it
If you have been working on it check your wiring is connected correctly - as in secure.
Oh and lastly - do you have an immobiliser alarm? - Sillier things have happend to others hence the question.
Can anyone else help with a consult cable?
Fixed,
Pulled everything electrical apart, cleaned all the terminals, put it back together, she's running.... :)
Not bad after 18 months on the blocks. Needs tuning, oil, coolant, and power steering fluid.
I prefer to run it at idle for 10 minutes stir up the fluids, then drain/replace. Otherwise the sludge stays on the bottom of the sump/engine.
once i get the fluids done I might PM you mitcho. Thanks
John
I agree John, but I also reccomend using engine flush - 15 mins on idle with this in, then drain. Repalce filter and oil.
Yes it does work and no it doesn't cause damage. I used it in the prelude last week, awesome...
Great news you have it running.
Must be like a kid in a candy shop.
Bet you can't wait to tune and drive :D
Ah cool i was wondering if that car belonged to someone on here, drive past nearly everyday lol. if it happens again check/clean the relays next to the ecu in the passenger footwell. if you need a hand just pm me, im in florey so only around the corner
