So the decision is made that I'm getting out of track days for the next few years.
To sell the car and make it roadworthy I'm getting rid of almost all the upgrades I’ve done over the past couple of years.
All parts are all still currently on the car and all working flawlessly. Its also daily so may take a weekend to remove parts. Car is a Black R33 GTS-T
If there is any interest in the car I am open to selling the whole package while everything lasts. Otherwise I will be putting back to stock before selling.
$1200 Power FC
$1200 Hypergear OP6 High flowed
$250 19 row Oil Cooler with Filter Relocation
$100 Drift Seat (Cheep autobarn special. The side is a little damaged by getting in and out)
$140 Harness Bar
$250 4 Point Harness
$150 Strut Brace
$150 Split Dump Pipe
$1500 Ksport 8pot Brake kit. (Calipers, 2 part disks, Bluestuff pads)
$150 ASI 52mm Radiator
$150 Xforce 3inch Cat Type 1
$500 1.5 way Mechanical Diff in housing.
$300 FMIC Kit
Can Post pics or welcome to view items on the car.
Make an offer to Rob 0430 310 430
Pickup from 3199
Type of harness bar? I'll be getting pictures of everything tomorrow afternoon.
Not sure what brand of diff, it came from a mates car when he bought it. He had two so I grabbed it for me. Locks up on power perfectly every time. Made oversteer out of slow speed corners much more predictable. Just in a standard R33 housing.
Cheers Rob.
Does your R33 GTS-T have abs?
Sorry mate I'm a Silvia guy, did a search and apparently they come in abs and non-abs? Stock ratio's 4.1 I think.. texting a mate now who knows more than I do lol.
You wouldn't have a photo of the centre? Just want to make sure it's a 1.5-way.
I'm keen to buy it but would need to confirm first.
Sorry mate, zoned out and forgot there was both abs and not abs. It's in an abs housing (has the hole for speed sensor) although its currently in a non abs car. I don't have a photo of the Center however I'll absolutly guarantee it's a 1.5way. Locks up hard under throttle and releases as soon as your off the loud pedal.
Here are some pics, anything ive left out just let me know.
Also Harness bar and Diff sold pending payment.
Hypergear OP6 R34 Highflowed turbo. You can also see the turbo side of the Split Dump pipe in this pic. Its once peice right though to the cat.
Strut Brace, radiator and crossover pipe for FMIC.
ASI 52mm High performance Radiator.
Ksport 330mm Big Brake kit.
Velo Harness. 3 inch shoulder, 2 inch lap 4 point. Rotating Cam lock.
Oil Cooler with relocation.
Update, the harness bar and diff are paid and gone. Ive had some interest in the car as a complete setup however at this stage everything else is still up for sale.
I forgot a few other parts to add to original
$80 Drivers side seat rail to suit R33 mounting points
$120 Front swaybar
$75 R33 turbo manifold
Also price drop on:
$1200 Ksport 330mm 8 pot brakes.
$1100 R34 Highflow Turbo
$120 Front swaybar
Also price drop on:
What sway bar do you have for sale and is it adjustable? What condition is it in?
Cheers
hi, interested in the turbo, what power are you making with it and how many ks has it done?
The turbo is a stock r34 turbo that has been highflowed by Stao at Hypergear. (do a search on the forums if your not familiar with him)
It has done approx 2000km since being highflowed still in perfect condition.
It was running at 12psi on mine which was doing 220kw at the wheels. The limiting factor was the stock injectors though. Stao's tests show 280kw is easily possible on E85 with supporting mods, around 250rwkw on ULP. Response is kept almost stock with this turbo which is why I purchased for track. I wasn't going for raw power.
Cheers
Whiteline front swaybar to suit R33. 5 hole adjustable. There are a few scuffs on the paint but otherwise its great condition.
Edited by bmdrifta
sounds good, how much posted to sydney?
Do you know what size the sway bar is? How many mm? Is it 24mm adjustable?
Also what condition are the bushes in?
How much for postage to 3025 post code?
Turbo is going to cost $30 to post to Sydney. Sale also includes braided oil feed line and fitting worth over $50.
Bushes are in good condition with no tares or anything. Yeh sorry mate, 24mm adjustable.
Would be difficult to post for less than $40 but your only an hour away with east link. Would be cheaper to pickup.
Cheers, Rob.
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
