Very sad im going to have to do this.
Due to some new exciting news i must sell the GTR as it won't be ideal keeping any longer.
Will also consider swapping for the right car.
Has been Rebuilt top to bottom with high quality genuine gear,
Gtr is in very good condition, just a couple of minor touch ups which i'll have sorted shortly.
Piston Originally failed on me due to a dodgy tune! So i decided to completely rebuild the motor and change the entire setup.
Current Power
315kw ATW @ 14psi
410kw ATW @ 23psi
Some of the Major Mods:
  • Garrett T04z turbo with dual entry 1.00a/r
  • xforce single manifold
  • Full Xforce Exhaust System
  • Haltech Pro Ecu
  • 1000cc Injectors dynamics
  • Carillo Forged Pistons
  • Scat Forged Rods
  • Turbo smart Dual BOV's
  • Greddy cam Gears
  • ARP head studes
  • SplitFire Coils
  • Nismo oil/air seperator
  • Titanium tomei valve springs
  • Machined ,Blue Printed and balanced including crankshaft etc.
  • Excedy/Daiken Twin plated heavy duty clutch
  • 125mm hyrbrid drag intercooler
  • Eboost 2
  • All braided lines with Heated Covers
  • Intank High Performance Bosch Pump - Ready for e85 in the future if needed
  • Upgrade Fuel Rail
  • Nismo Oil pump (not N1)
  • N1 water pump
  • Gates timing belt
  • Genuine Carbon fibre engine covers with Candy Red.
  • Block completey painted in candy apple red from Queen street
  • Limited Edition Bronze XXR wheels with Forceum semi slick compounded tyres 245/45/17
  • Nismo 320km Dash Cluster
  • Clarion 7'' touch screen unit with bluetooth.
  • complete Soundstream sound system.
*Brand new tyres going on this Friday. (275x40x17).
+ many more items which will be reflected on the invoices aswell as dyno sheets.
All modifications were completed 2000kms ago,
***Will have more photo's within a couple of days, Limited on photo's at the moment as I'm interstate.
I do have a small build thread if you require more details in the mean time.
Located around the Ryde Area.
Contact: James 0452073044
Price$30,000
Edited by binga85
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
