#R33 front upper camber arms *brand new never installed* great for any lowerd r33 to prevent inside tyre wear or to run more camber for big offset wheels.txt for pics blue in colour $150ono
#R33 series 1 tps (throttle position sensor) got it off a mate in good working order $15
#R33 vct sensor (variable cam timing sensor) got it off a mate comes with new o'rings SOLD
#R33 drivers side power window switches in great working condition $50
#bm44 brake master cylinder with ABS $20
#R34 injector loom $10
#R33 2x front brake rotors just need a shave no groves and have never been machined great condition $30
#Tial 44mm wastegate springs *large gold *medium gold or brown *small gold or brown *small beige $30 the lot
#R33 3.5 inch 6 bolt dump pipe from turbo to cat with o2 sensor fitting direct rb bolt on dump may also fit R32 and R34 $50
located on the central coast nsw and will post most parts at buyers expense.feel free to make offers also.txt for pics 0401683376
  • 3 weeks later...
hey mate pics please of the BM44 master cylinder to kirasuran@gmail dot com , was it all working fine when taken out? Mine has a ticking noise at times it seems...
it was in perfect working condition and i kept a bit of fluid in it to prevent the seals drying out.could i send pics to ur mobile if possible pm me ur number cheers
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
