I have an annoying mark on my dash facia from the previous owner which by the looks of it needs to be sanded off and repainted :/
my question is, after i pull it off and sand it whats the OEM colour for the dash so i can prime then respray? its a rough-ish finished black but i doubt anything an autosalon have would be suitable.
any help would be great!
Edited by AdrianGTT
https://www.sau.com.au/forums/topic/416444-respraying-r33-s2-dash-need-help/
you might be able to get away with using some prepsol/wax and grease remover as it looks like leftover glue and it might come away.
best bet is if you want to respray it, I would go with a satin finish more than anything (also match the drivers side arm rest/window switch area) but i beleive that would be the closest match, unless you want to get it wrapped in a sticker?
havent tried it but just some opinions/ideas.
unfortunately its not left over glue, its actually melted away the plastic there.. some rough super glue would be my best bet but yeah regardless its still annoying
im thinking maybe test an inconspicuous area of the dash and see how it goes, i just dont want to do anything ill regret after :/
Mate I'm in the same situation with the r33. that sort of rubbery matte black finish is awesome but I can't find anything the same. Closet thing I found was at Repco, it was a black bumper spray that is supposed to be like a spray on car bra. I thought about it but after reading the directions on the can, it is designed to be removed with a high pressure car wash hose, so it'd scratch pretty easy I'd imagine. I'm goin for the matte black wrap when I get some time.
My opinion would be to sand it back, prime it and give it a few coats of this.
I resprayed my steering column surround without using primer and it still came out amazing. Not 100% the same colour as stock but looked very good. Then get a clear coat and go over it to protect it from scratches etc.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
