Hey all im new to the RWD side of the car, iv owned afew rwd in the past but most of my past rides have been hondas
atm my current ride is a 1992 honda prelude f22
i got this car about 18months ago as nothing but i shell and managed to rebuild in to what it is today
afw mods i have on the car are,
body kit
shaved boot lid
halo head lights
clear tail lights adj sleeved springs
the motor is an stock f22 but as we speak i have a new f22 being built for it. its a fully forged 2.2ltr with a stage 2 turbo cam, upgraded springs, vavles, retainers, and guides ect ect
its runninf twin walbro 255s with nos and a t04e good for about 600hp all running off a hondata
with a little luck once i got the new motor in i would be happy if i can manage 350-400hp atw @ 15-20psi
here a few pics of what i started with to where i am now
and this is where i am now
now i know some of you are prob wondering WTF is this guy banging on about? this is a nissan spot not a honda spot......
well over the next few weeks im going to be on the hunt for an R34 shell to start on and do it all over again, and would reall be greatful
for any advide you lads can give me or questions i might have,
the plan is to build a proper drift spec 34 that will get used and not just sit there and look good parked up.
so i guess the first question i have is.........
is there anything i should be aware of or be on the look out for while looking for a shell, parts or even suggestions on what parts to use that wont shit its self after one run.
and befor anyone ask, yes i do understand this is not going to be a cheap project...........(just dont tell my misses, she thinks the turbo for my honda is part of the aircon lol)
thank any help would be great
https://www.sau.com.au/forums/topic/416540-hello-from-qld/
Have you drifted before?
If not I'd be getting a cheap R32 thats already running with a RB25 in it, (Or just get an R33 GTSt since theyre just as cheap but newer) add a FMIC, Oil Cooler and steel wheeled turbo, weld the diff up and go and learn to drift in it.
You are very likely to keep bending things, and the cost to build a car from shell/rolling chassis most of the time is more expensive then buying individual parts.
It's why a lot of guys are parting out their R33s as they are getting more money for them in parts. Plus if you decide you want to put in a new part, you've got the old one to either sell, or keep as a spare (What I recommend) for if/when it breaks.
https://www.sau.com.au/forums/topic/416540-hello-from-qld/#findComment-6687460
yeah i have drifted befor, its been a few years, but my last drift car was a vt gts 5.7lt 6spd man with a charger but i dont plan on doing this over night its just going to be over time and the way i see it, if i smash a 32 or a 33 its still going to have to be fixed if it were a 34, and on the plus side i know a thing or two about doing body work on cars, i used to work for a body kit shop doing alot of repairs on drift damage and also build wide bodys
https://www.sau.com.au/forums/topic/416540-hello-from-qld/#findComment-6687473
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
    • There is a warning that "this thread is super old" but they ignore that anyway...
    • With 10% Ethanol, we're talking 2-3% fuel consumption difference. The emissions reductions and octane boost in my opinion far outweigh this almost non existent loss.    My tanks sitting at 80%. Luckily that should go down fast as I'm on vacation again for the next two weeks.
