  • Replies 47
No one has mentioned Hankook Evo V12, well priced and similar to Michelin PS2, Federal RSR but way cheaper..
Im on Hankook RS3 now.. do soft and soft on sway bars, get some coil overs and do 8 -8 or 8 - 12.
the more you go down from 20 the lighter the wheel = better for performance, cheaper tyres so you can afford better quality etc
standard V35 has a fairly stiff, modern chassis which is a good baseline for good handling, although arguably its closely-related Z33 stablemate is a better base as it is a good 30-80kg lighter (depending on spec) and has extra under body and chassis bracing as standard.
standard characteristics is fairly neutral, with mild understeer near the limit and can have some power oversteer. like in this best motoring vid:
any car thats almost 10 years old may need a suspension refresh (bushings, maybe worn shocks, etc) to perform at as-new level.
lowered springs not matched to the shocks will increase shock wear and reduce handling capability. as will putting on crap tyres which seems to be unusually popular amongst skyline owners for some reason.
if you look at most serious handling-focused setups for V35/Z33 they will use 18 or 19" at the largest wheel, but of course wider and more agressive offset than the standard rims.
Switched to Nitto Invo (285/30/20) on the rear after going thru a set of Yokohama Advan Sport V103. The Nitto cost me $350ea from Taleb (sponsor) and are quite comparable for grip and are a little quiter. The yokohama are a slightly better handling tyre all round but are twice the price so my choice is Nitto.
Not yet Pn-Mad.. thanks for asking! Been out to the beach all weekend.. didn't get to work on my car! lol! My car is usually stuck in the garage for a weekend jaunt... Yeah .. I;ve been looking at the Nitto tyres.. I just read about the Nitto Motivo... apparently long life for a 20 series.. anyone has experience with it? Btw mosoto.. how long did that Yokohams cost you before? And long how did it last?
I am quite curious to know how Nitto Invo and Nitto Motivo goes up against Yoko and Dunlop.
Am currently running Dunlop Sports Maxx and I really like it. Advan sports and S-drives are really good to use as well. All have good grip during dry and wet weather. For the occasional track days :)
Edited by colin.ssc
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
