  • Replies 47
No one has mentioned Hankook Evo V12, well priced and similar to Michelin PS2, Federal RSR but way cheaper..
Im on Hankook RS3 now.. do soft and soft on sway bars, get some coil overs and do 8 -8 or 8 - 12.
the more you go down from 20 the lighter the wheel = better for performance, cheaper tyres so you can afford better quality etc
standard V35 has a fairly stiff, modern chassis which is a good baseline for good handling, although arguably its closely-related Z33 stablemate is a better base as it is a good 30-80kg lighter (depending on spec) and has extra under body and chassis bracing as standard.
standard characteristics is fairly neutral, with mild understeer near the limit and can have some power oversteer. like in this best motoring vid:
any car thats almost 10 years old may need a suspension refresh (bushings, maybe worn shocks, etc) to perform at as-new level.
lowered springs not matched to the shocks will increase shock wear and reduce handling capability. as will putting on crap tyres which seems to be unusually popular amongst skyline owners for some reason.
if you look at most serious handling-focused setups for V35/Z33 they will use 18 or 19" at the largest wheel, but of course wider and more agressive offset than the standard rims.
Switched to Nitto Invo (285/30/20) on the rear after going thru a set of Yokohama Advan Sport V103. The Nitto cost me $350ea from Taleb (sponsor) and are quite comparable for grip and are a little quiter. The yokohama are a slightly better handling tyre all round but are twice the price so my choice is Nitto.
Not yet Pn-Mad.. thanks for asking! Been out to the beach all weekend.. didn't get to work on my car! lol! My car is usually stuck in the garage for a weekend jaunt... Yeah .. I;ve been looking at the Nitto tyres.. I just read about the Nitto Motivo... apparently long life for a 20 series.. anyone has experience with it? Btw mosoto.. how long did that Yokohams cost you before? And long how did it last?
I am quite curious to know how Nitto Invo and Nitto Motivo goes up against Yoko and Dunlop.
Am currently running Dunlop Sports Maxx and I really like it. Advan sports and S-drives are really good to use as well. All have good grip during dry and wet weather. For the occasional track days :)
Edited by colin.ssc
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
