dw im not a wanker on the road :)
i had an s14 before this with 235rwkw 864nm and got raappppeeeddddddd on red p's..... i want this one to be as subtle as possible :) and im not gonna go for huge power..... might go up to a 2860 or 2871 with bigger cams and injectors when i get off p's :) hopefully get around the 250rwkw mark safely :)
  • Replies 45
if i can get more safely with that size turbo then awesome :) cause i dont want too much lag.....
and i like the sound with cams
you know, alot of the cam sound is from the tune, with mild cams its almost undetectable, but with the mixtures changed at idle you can get the fat cam sound or even without cams get the sound.
thats interesting! does it affect power or fuel safety of the engine?
i dont think so, its just the mixture on idle, obviously you need an aftermarket computer for that
with mine, as soon as the mixture was leaned a touch it would give the rough cam idle, but i prefer it with a smooth idle and odd lump to it.
Mark with your cams and turbo you should be making a bucket load more power than you are...why have it if your not going to use it.. most blokes with a basic hiflow setup would give you a run for your money any day...cams are not really needed in Rb25s unless your pushing for big numbers the stock cams are good to 350kw sometimes more...
yeah well with a forged engine im sure the gtx would make upto 380rwkw, i think if you run a gt30 or larger a set of cams doesnt hurt, it makes 320kw on 16psi which is nice and safe, i dont want to be doing a rebuild anytime soon, and yes they'd give me a run for my money cause they'd have more traction for sure, maybe in third id hose them off :)
You don't need a forged engine either....just a tuner willing to push the envelope. :P
haha , you go first then.. ill watch from outside the dyno room incase a pistons decides to depart ...lol
my turbo (actually my whole setup) isn't big enough, its pretty much close to maxed out as is....
but thats why i chose it cause it suits my power target...all i'm saying is why have it if you dont need it or not going to utilize it..
I'm not knocking your setup its killer, im just saying i want to see you turn the volume up..
It could be good for 400kw or you miay as well have got a smaller turbo ;)
yeah your 100% right, if i were doing it again id of just gone gt3076 maybe with a 0.63 rear even with E85 and hoped to max out at 300ish
went gtx cause it sounded like a good thing, 10%more flow etc but its actually suited for a forged motor really, but also down the track i would like to attempt a rb30/25 or maybe just a forged rb25 , so then the boost will be wound up to 25psi.. i like to have alot of room for more power down the track and really its not bad, 20psi at 4000rpm shes on par. ;)
we pushed mine to 21psi but nothing exciting happened...extra 10kws or something...have you tuned past 16psi at all, and is that on e85 ??
no havnt gone past 16psi at redline and yeah E85, it was responding very well to boost and timing advance, each psi was like 10kw or more and knock levels very low, the fuel makes massive difference went from 280 to 320kw with no more boost needed.
So did the tuner decide 320kw was the safe limit or did something else hold you back?
  • Like 1
well i asked him what he thought was a good safe limit and he said 1.4bar is what he'd take it upto on E85, i was only looking for 300kw so when it hit 320kw first run i thought, wow i think ill leave it there in case somthing goes pop... it must of cost about 5k atleast upto that point and dont wanna spend more if anything goes wrong..
Quite alot of people say running over 300kw's is a gamble so i didnt want to push it incase it went bang, and i love how it sounds and drives as it is..
sorry daniel , dont mean to take over your thread.. :/
Edited by AngryRBGTX
Mission accomplished then!! Still would be cool to just do a few dyno runs at 20+ psi to see what its fully capable of.
+1 ....and I'm intrigued to know why tuner didnt try it...if it was responding so well why give up on it....we all know an RB can push further, even if you just did it for tuning then cut it back....it also gives you a safety margin should you hit any overboosting issues down the track..I'd say 300 is a gamble but you're pretty safe on the dyno, its the varying conditions it sees in everyday life that would cause issues...
you could be restricted by that vegan clutch though....should of gone carbotic... :rofl:
+1 and I'm intrigued to know why tuner didnt try it....if it was responding so well why give up on it....we all know an RB can push further, even if you just did it for tuning then cut it back....it also gives you a safety margin should you hit any overboosting issues down the track..
im intrigued now too.. lol well it was with a 250kw rated clutch, ive no doubt it would of seen atleast 350kw, if you watch the dyno video you can see it backs off after 5000rpm so it had heaps left, i will eventually build a bottem end up and go back for 350kw plus its still a goal...
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
