SERIES 1 PARTS
rb25det series 1 afm green label great upgrade for rb26 I've got 2
$50 or 80 for both
r33 gtst rear 5 stud conversion
hubs
rotors
calipers etc
$250
r33 gtst front hubs, rotors and brakes good for 5 stud
$200
r33 gtst drive shafts
great condition
$30ea
r33 rear cradle just the cradle
$20
r33 gtst brake master complete non abs
great condition
$30
r33 custom one peice tailshaft
$90
r33 engine crossmember perfect for rb conversions
$50
R33 power steer rack
Great condition
$30
r33 front sway bar
$20
r33 series 1 behind the dash aircon stuff
make a offer
r33 series 1 window trims from door and car the one that always fade
make a offer
r33 overflow bottle
$10
R33 gtst ignition barrel and locks with key
Good condition
$130
R33 gtst side mirrors
$20 each
r33 passenger side gaurd with blinker
maroon
$20
R33 series 1 dash
$30
R33 gtst centre console
Good condition
$20
R33 doors bare
good condition
$20 each
R33 gtst tail lights
Great condition
$20 each
R33 glovebox
$20
R33 boot with aftermarket wing/spoiler looks similiar to standard one lights up skyline
$20
R33 handbrake with full handbrake cable to hubs
$30
R33 passenger window reg motor
$35
R33 passenger window switch
$20
R33 bonnet latch and cable
$30
R33 bonnet latch bracket
$20
r33 boot and fuel flap latch assembly
$20
r33 air con unit/display
$20
R33 complete air con set up with everything!
condenser
compressor
dryer
lines etc
$130
SERIES 2 PARTS
Rb25det series 2 motor from 97 model
Blue painted covers
Complete with Loom and ecu
115000kms
$1250
R33 series 2 auto gearbox has been modified and tricked up not sure exactly but also comes with a trans cooler
$100
Bare rear subframe
$20
rb25det series 2 afm pink label great upgrade for rb26 just need 1 more
$60
hubs
rotors
calipers etc
$250
r33 gtst front hubs, rotors and paint gold brembo brakes look like r34 Gtr but are standard r33 look awesome
$300
r33 series 2 gtst drive shafts
great condition
$40ea
r33 gtst series 2 brake master complete abs
great condition
$50
$50
R33 series 2 power steer rack
Great condition
$30
R33 aftermarket front strut brace
$40
r33 front sway bar
$20
r33 series 2 behind the dash aircon stuff
make a offer
r33 series 2 window trims from door and car the one that always fade
make a offer
r33 gtst series 2 ecu
$60
r33 series 2 gtst engine loom perfect condition
$150
r33 overflow bottle
$15
r33 gtst series 2 front seats
Great condition drivers have minor tear
$50
r33 gtst series 2 door cards front and rear
good condition
$100
r33 series 2 rear bar silver
$40
R33 gtst series 2 ignition barrel and locks with key
Good condition
$130
R33 gtst series 2 side mirror passenger silver
$30
Silver
$30
R33 gtst series 2 centre console
Good condition
$20
R33 series 2 door passenger
good condition
$20
Great condition
$30 each
R33 glovebox
$20
$50
R33 pasenger window reg motor
$35
$20
$50
$40
$30
r33 series 2 air con unit/display
$30
R33 series 2 complete air con set up with everything!
$150
i have all the interior plastics etc
So much more just can't think text me or pm me if you need anything
Gold Coast can post
0487924497
i have all the interior plastics for series 1 and 2
Gold Coast can post
0487924497
Hey guys ill be going to Sydney early next week with a car trailer so if you need any parts ill bring them with me or if you know anyone that needs a car transported from Gold Coast to Sydney I can also do that for fuel costs
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
