S1 rb25det engine 113,000km
All accessories, turbo, loom, ecu
$1400
S2 rb25det engine 102,000km
All accessories (minus coilpacks because they are stuffed)
Turbo included, ecu, loom VERY GOOD MOTOR
$1600
Rb25 det gearboxes with shifter and crossmember
$1100
R33 tein adjustable coilovers No leaks
$500
Front and rear strut braces,
Standard r33 mspec rear brace $100
Cusco rear brace $80
Cusco front brace $80
Nismo rear brace $100
Nismo front brace $30 ( brake stopper bent)
Cusco tubular front brace $70
R33 exhausts
3 inch cat back $100 x2 available
3 inch turbo back 150
Full greddy (TRUST) system $300
Series 1 and 2 wiring looms $100 each
Rear lights $44 each, burgundy, white and black available
Headlights s1 $110 each s2 $220 each
Front reo s1 (cut for cooler) $50
Front reo s2 (uncut) $110
HKS intercooler, piping and hose fittings kit ( full HKS )
$300
Greddy intercooler and piping kit ( no brand silicon hoses)
$250
Z32 afm with ss elbow and pod $100
All parts in Elizabeth SA can post any item at buyers cost
All interior parts available, all panels for series 1 and 2,
Hey mate
Can you post pics or send me pics of both your Intercooler cores and piping that you have and the Greddy/Trust Exhaust?
PM me if you can only send them by phone though, so i can send you my number.
Cheers Matt
Sorry guys I can't post up pics atm as I've just moved into my new house and will have no Internet for a few weeks, text me on 0433368063 and I can mms some thru
The gearboxes and engines are in perfect condition, you may ask anyone ive sold my parts to, simon michelmore, jake jones, david and Kelly from sleeka spares brenton from fours and more, streewise mechanical and the list goes on, unfortunatley one box is sold pending payment and other is on hold till sat, gotta be quicker at these prices however first one to text me will have dibs on the last box as I don't think the second buyer is genuine
Z32 sold pending payment, gearboxes sold, s2 motor sold
2 engines left
S1 rb25det 140,090km $1300 complete with turbo
S1 rb25det 113,000km $1400 complete with turbo
Nismo front brace sold
Nismo rear brace sold
Z32 back up for sale
These motors are in great condition guys!! Come grab a 25 !!!
I've got a blitz return flow available if your keen, off a working s2 r33, fits in without cutting the reo, pm me if keen!
how much for this bro?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
