Hi Guys,
I have a r32 gts-t that has 158.8 rw kw's at the moment and Im happy although Ive got that urge for more power.
I was planning to buy a hks 2530 or 2535, some series 4-5 rx7 injectors, hks cams and few other lil bit for my current rb20.
A mate of mine lent me a hpi mag that has a r32 gts-t with a gtr engine transplant. The engine was basically stock with a huge cooler and re-mapped ecu and at 14psi he had 230 rw kw's. An rb25 gearbox would be needed too.
I think that the gtr engine option sounds mad, and having round 230 rw kw's is far from pushing that engine and the rb25 gearbox will hold up also.
What do you guys recomend?
Also if you know briefly what it will cost, please give me some idea.
Thanks
Mark
https://www.sau.com.au/forums/topic/41802-what-is-best-to-do/
a RB26DETT will set you back about $6.5K for a good condition one.
add another $1.1K for the RB25 gearbox
plus labour if you don't plan to do it yourself.
I'd personally get some cams and injectors as they are some relatively "cheap" mods that have a big impact. (Make sure your fuel is up to scratch).
thanks for the advice guys, I have come to the conclussion that the rb26 will be a waste of $$$ for my needs. I will also have to change my cooler and exhaust to suit.
I could get a rb25 with gearbox and fit a hks 2540, injectors and power fc, without having to change my cooler and exhaust.
do you guys think a rb25 r32 is worth it?
i like the idea of the stronger gearbox too :(
take it easy
Mark
    • Wow ELVIS. You have an....interesting approach to conversation. Did you not notice that I wasn't talking to you?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
