Hey everyone my pride and joy is up for sale.
Ive owned the car about 4 years now it was road registered up until a year ago when i turned her into a track only car
I used it for track and club days out at winton where i got my best time of 1:45.
Car has never been drifted!
Car
1993 R32 Nissan Skyline GTS-t
Not registered TRACK ONLY!!!
Gun metal grey
Motor- 167,xxx ks
Motor
RB20DET
Hypergear Hiflowed R33 turbo
PWR Intercooler with return loop piping
Splitfire Coils
3” Turbo back exhaust into Xforce cannon muffler
K&N Pod filter enclosed
Turbosmart boost Tee (12-13psi)
Alloy Radiator
Gates Racing Timing Belt
Permaseal MLS-R layered exhaust manifold gaskets
NGK iridium spark plugs
Drift catch can with filter
Walbro high performance fuel pump
Battery relocated in boot
Aircon completely removed
H/Duty clutch (brand and age unknown)
Suspension/Handling
HSD Coilovers F-8kg R-6kg
SRI adjustable front castor rods
R33 lower control arms
Solid steering spacer/bush
Gktech adjustable rear camber arms
Whiteline sway bars front/rear
Whiteline Hicas lock bar
Whiteline front strut brace
Nismo rear strut brace
Hicas completely removed
DBA slotted rotors front/read
Bendix ultimate pads front/rear
Ferodo 5.1 racing brake fluid (flushed regularly)
Brake master cylinder recently rebuilt
Brake master cylinder stopper
The car uses Dunlop formula R semi slicks 225 / 50 / 16, which are on a set of R33 GTS-t rims. I also have another set of the same semi slicks on the standard R32 GTS-t rims (tires are pretty dead one has a flat spot) I’ve just kept them as spares.
Exterior
Type M side skirts
Rear spoiler removed(holes filled and painted)
Rear wiper assembly removed
LH head light replaced with fibreglass air intake
Front bumper cut to fit intercooler
Bonnet pins
Interior
Autotechnica fibreglass bucket seat(driver)
OMP 3” 4-point harness(driver)
Standard R32 passenger seat
Autotechnica 2” 4-point harness(passenger)
Turbosmart boost gauge
JJR 350mm suede deep steering wheel
HKB boss kit
D1 steering wheel quick release kit
Dildo gear knob
Fire extinguisher
Interior has been completely striped no tar, sound deadening, glue, padding, including the boot.
Heater and aircon are gone. All plastic trimming is gone( except door cards )
Info
Car is serviced every couple of track days using Penrite oils, this includes the gearbox and diff which was last done about 2 months ago.
Water pump was replaced when the timing belt was done for peace of mind ,which was about 2 years ago.
I’ve replaced a lot of the hoses over the years including water, vacuum and power steering.
90% of the steering parts would only be 6 months old.
I’ve painstakingly looked after this car from the day I got it and have spent a lot of time and money doing so.
The clutch bearing is a little noisey and the pads dont have much life left
The body has the normal amount of bumps and scratches.
Will be very sad to see it go, I said I’d never sell her but unfortunately times change.
Price
I’m wanting $7000ono but am very open to offers. I need the car gone in the next couple of months but will not be low balled into giving it away!!! Like I said I’m open to reasonable offers!!
If you want any more info feel free to ask, I’m not on the forum much so call or msg me on
Car is advertised else where also
0-4-three-8-six-7-3-nine-4-five
Will get more pics up tomorrow.
https://www.sau.com.au/forums/topic/418185-1993-r32-gtst-track-car/
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
