Hi Guys
This is aimed at the 34 GTR guys that have removed/locked the HICAS system. I have searched for about an hour now on here and on the mystical google but i cant find anything in direct reference to what is involved in locking/removing the HICAS from a BNR34. its all the 33's and 32's. Is anyone able to tell me exactly what parts and the procedure involved in doing this for the 34?
A m8 has a 34 GTT and his HICAS was locked with a lock bar and taking some plugs out, but i have a power steering reservoir in my boot so im assuming that its not going to be as simple as that.
https://www.sau.com.au/forums/topic/418324-r34-gtr-hicas/
Hey Adam, why are you putting in a lock bar? Is the rack screwed? Track day coming up? HICAS enhances corner turn in & hence improves performance. I LOVE my Super HICAS in my wagon, it is very noticable cornering at speed, compared to more relaxed driving!
https://www.sau.com.au/forums/topic/418324-r34-gtr-hicas/#findComment-6726092
I hate the HICAS, every corner i take at speed on the road (normal driving in 90-100km zones with corners) it pushes the car out towards the worng side of the road as its designed for track use and not single lane roads. I also hate the feeling of the car when it kicks in, feels like the rear end is floating. Everyone i know says to lock it ASAP even in the 34 GTT with HICAS and i know y they say it now.
https://www.sau.com.au/forums/topic/418324-r34-gtr-hicas/#findComment-6726757
I know what you mean. When I first got my R32 it was terrible, push it hard through the apex & exit of a low speed corner & it would go in completely the opposite direction I though it would! I played around with the wheel alignment after work for afew nights & got it pretty good. It was much more predictable, without losing too much of the entry feel. I find the responsiveness of my Stagea to cornering at speed excellent! I don't feel the floatiness in the wagon, maybe because of the extra weight over Skylines. It would be really good if the HICAS management was adjustable, to allow a more progressive application......
https://www.sau.com.au/forums/topic/418324-r34-gtr-hicas/#findComment-6727454
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
