IDa will be holding a drift event at Eastern Creek on Saturday, 5th of June, 2004. The event will be held on the Eastern Creek Skid Circuit, a concrete low friction surface.
We will be running 2 sessions. The first in the morning will run from 9am to 1pm on a wet track. This is a perfect opportunity for those wanting to "give it a go" to get out there. The second session, run from 1pm-5pm will be on a dry circuit.
You may register for either one or both of the sessions.
Should you only wish to participate in one session (either wet or dry) the cost will be $60 to members and $75 to non members.
Full Day (Both Sessions) $100 to members and $130 to non members
Special Requirements
As a member of CAMS, Initial Drift will be requiring that all drivers and passengers wear long sleeve shirts and pants covering ankles to wrists to neck. Appropriate footwear must be worn along with a CAMS approved helmet (any AS helmet will do).
These requirements are not open for interpretation and are ultimately for your safety (http://www.initialdrift.com.au/forums/view...php?p=6608#6608). Please ensure that you bring the necisarry gear as you WILL NOT be running without it.
CAMS Licensing
For insurance reasons all drivers must hold a current CAMS license. Should you not have a current or valid CAMS license, that is OK. Initial Drift will be issueing daily licenses for $20. Passenger will also need to hold a CAMS license.
Register your attendance here: http://www.skylinesaustralia.com/forums/ca...do=getinfo&e=57
boxheadmr, can I please get a link to the supp regs and entry form so that I can add it to the calendar entry
Thanks
Tosh
I am sorry to hear that B-Man - PM Sent for your views on the day
This is only a practise day, all the info that is required in regards to what you need for the day are above.
To Pre-Book your spot send me an email on [email protected]
Thankyou for putting it into the events section :)
Hi Matthew - I have sent you a PM - Thanks for the opportunity to give you some feedback - please take it as constructive.
Apologies for my in-appropriate response to your post above -
Good luck with the day.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
    • I use FCC car launcher. It has an option for different backgrounds, so instead of turning the screen off you can swipe 'up' to a black screen with no background/icons. (mine has the time on it only). It's kinda nice. Also lets you use gestures to say swipe to go to next song, etc.
