We should get on the leaderboard for SAU NSW too for intruding an event.........
Post up who is coming so we know what the deal is, by now you should have paid your entry fee and filled in the application form! For those planning more motorsport during the year you CAN get the CAMS LS2 speed license for 12mths on the day!
  • Replies 59
Me and my bro are entered
Perfect, where are you meeting?
So we have -
Entered:
Me - 34GeeTeeTee
Ben - BenRThirtyFour
Bro - BroRThirtyFour :P
Andrew - FeZ25
Matt - DekA
Chookie??
Spectating -
Ant - GTR 34A
i know there is more..... But who?
Excellent attitude.
Barrel rolls are for champions.
If you dont roll you are too in control! If you are in control you are a homo!
Whens the Next hillclimb ?
There is a wrap up thread now Jesse under the NSW section.
There is also details of a Buladelah one in the Events section.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
