Cheap! Ssrs,takata Harnesses,nardi Personal Wheel + 33 Boss Kit,hks Gauges,r32 Gtr + R33 Gtr/gtst Stuff!
Getting rid of everything un-needed and takinng up space.
SSR Veilside Marriots
3-piece wheels
18x9.5 +23 All round
265 Tyres
Also have the centre caps for them
Been stuffed around with these a few times so price drop to $800 FIRM!
I believe these wheels come off a Veilside R33 GTR as these are rare in these sizes and offsets
Nardi/Personal Steering Wheel GENUINE*
with a R33 Boss kit from a GTR
$150 for both FIRM
The wheels retail around the $300 mark alone
2x Takata Harnesses (Non Genuine)
no eye bolts
Used for 2 track days no wear what so ever
$80
Discontinued HKS Gauges
1x Exhuast Temp - x100degrees
1x Intake Temp x10 degrees?
1x BAR/Pressure up to 10KG CM2?
The intake temp is missing the wires that read the tempreture
$100 FIRM for these
Also have a bigger HKS Boost Gauge up to 2.5 Bar but unfortunately missing the wires
$20 for it
r33 GTST Nismo Front Pipe 3" Titanium (im assuming) $50
R33 GTR Stock rear strut brace may fit GTST
$50
S13/180SX Cluster with 2xxks
$20
R33 GTR Centre Gauges standard
$50
R33 GTST Cluster 123xxxks
$50
R32 GTR
Airbox + Airflow meters $150 FIRM
Radiator + Shroud $80
Front Pipe $50
Fan $30
SR20DET motor
Bearing has slight ticking/knocking
On idle made no noise but rev it to 2000rpm you could hear the sound.
I took it straight out of my car before it did any real damage
Missing DET rocker cover (as i put a DE in my car and added the turbo for the mean time)
Also missing throttle body
Has cams but they are out as it had pon cams
Also comes with turbo manifold
and turbo injectors
$200 for it
SSRs
takata Harness
Fan
SOLD
steering wheel SOLD pending payment
SR20 probly keeping due to new daily s13
Edited by ISLIDE013
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
