Hey all i no this has prob been covered iv tryd finding/reading but i just dont understand it
Iam looking at new wheels for my r34 gtt and have found these
18x8 +45 5x114 with 225 tyres i really have no idea what this means apart from 18inch and the tyre size
So will these fit my car nicely with out sticking out the guards or to far in.
https://www.sau.com.au/forums/topic/419192-need-help-asap/
Yer there the same size as stock. just 18s so new question
Right above my stock wheels there somthing idk what it is but i assume its something to with steering and my stock wheels are about a inch or less away from the rear gards so would that make the 18s a no go with out gard rolling i have cusco coils but i dont think my cars that low or i can get drift teks the same size as the stock gtt wheels but there gold and my cars white what use think
Links to adds http://www.gumtree.com.au/s-ad/morphett-vale-area/wheels-tyres-rims/koya-drifteks-gold-for-sale-or-swaps-/1012053457
http://www.gumtree.com.au/s-ad/highbury/wheels-tyres-rims/18-x-8-45-5x-114/1012307623
Edited by gts25tnissan
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6735108
225's are damn skinny the rear will break loose easy and fronts push out on power too soon , like uturns under power without a clutch kick lol
My fronts are 245 ,rears 285 on 18's no hitting at all if your not dumped in the weeds
and your alignment is setup properly
And the offset is near stock cfr what stock was?
If you can get a few fingers between your front gaurd and tyre your prob ok unless you hit a pot hole while turning or curb driveway at full lock
if anything bend the inner lip of the guard near the top , folded it tighter just a bit so the tyre wont grab it and flog it , make sure the liner is held up properly too
Edited by Carbon 34
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6735198
If the offset is higher than about +35 the wheels will more than likely hit your suspension anyway. A 9j +20 will sit nice and flush with the front of a 33 and the rear can go a little lower in offset or higher in width.
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6735616
Ok last try i found some more gumtree add is http://www.gumtree.com.au/s-ad/parafield-gardens/other-parts-accessories/street-drift-race-rally-items-no-longer-needed/1013603913 was looking at starcorps and sorry krishy dont realy wana go to stock would rather save till next payday but then the missis and the hole u spend more on ya car then me lol
Sorry just ead petes post they wont fit grrr whys there no rims on gumtree when i have some money there always is when i have none
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6735764
Hey all my mate wonts to race me at malla nats in november i have a r34gtt with fmic pod and 3inch turbo back. He has vt ss with 320kw at the wheels so he says. hes mods are maffle tuned port and polished head and a milled cam prob a few more i stop listening after awhile. what mods do i need to make that sort of power. I have about $1500-2000 to beat him lol.
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6740519
Haha change brake pads ebc yellow or A1RM by qfm, some RBF 600 or 660 brake fluid then well setup coilovers and you will beat him
Edit - when you beat him with 200kw he will be crying and Mallala is a brakes track too so having 320kw without touching his brakes he will be trying to stop at 300meter if you sort good brakes out oyou will go deeper
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6740578
Hey na he wonts to do the burn out pad drift and drag. I cant do drift or the skid pad even when my tc is of my car still stalls at highish rpm its auto aswell. So was thinking shift kit prob cant afford a bigger turbo. I have cusco coil overs and i ended up geting those starcorp wheels they fit real tight but i can feel there heavy as f**k. Yer and this all stared cuz i beat him at mario kart lolol
https://www.sau.com.au/forums/topic/419192-need-help-asap/#findComment-6740643
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
