FOR SALE
My 1998 model R34 GTT skyline. only 85000ks
as far as i can tell, the speedo seems to be showing legit klms.
great car but i need a bigger one.
manual
turbo
2 door
19 inch advanti wheels with new GOOD tyres on front 50% tread rear
pioneer blutooth head unit with ipod connect
NISMO S-TUNE suspension all round with adjustable dampeners
diff has been shimmed by pervious owner (not too aggressive)
modified standard boost solenoid to run 8PSI all the time
has a small rust bubble behind drivers rear wheel arch. been told its and a good spot and should be around $300-400 to fix but i just dont have the time to get it done.
never been raced or flogged while ive owned it
cant think of much else at the moment.
i want $15000ono for it, SMS 0432663963 with any questions or offers.
https://www.sau.com.au/forums/topic/419328-for-sale-r34-gtt-2-door-manual/
  • 3 weeks later...
  • 3 weeks later...
  • 3 months later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
