Yeah but proven to bring boost on 500rpm in most applications I've even read somewhere boost come on nearly 1000rpm earlier. A mates mate had one for his 33 and he'd never seen a manifold that clean inside, the welds get ground smooth and polished almost, quality stuff really, and I guess the saying you get what you pay for shines here
yes very true ill look in to it a bit more i mean you want the best you really have to pay for the best i guess
on another note anyone seen one of these before come in a box of stuff with the car
good day today went up to mates to cut the section of engine bay i need to repair my laurels rusted bit out of his shell and found that his shell still has the clutch and break pedals and a manual dash cluster :) so good saved myself few $100
are yeah shit i was looking at that forgot about you umm i did see the fuse box i know there is a hole engine loom there but i cut it in half when i took the half of the car off but the rest is there i think message him and ask he would know whats there but there is defs a fuse box still mounted in side the car
well yesterday i sold the r32 thank god so now the manual gearbox will come and getting closer to doing the conversion spent today putting on the new steering rack boots and taking the aircon pump out (as it was left in there with just the pump and nothing else) still waiting on the manifold and other gaskets to come then put all that back on cant wait to drive it again even if it is auto
alright so im almost there with all my conversion parts ive got a question ive searched and havent been able to find the answer...
As im putting the 25 box on to the 25 motor what sort of sandwitch plate will i need to bolt up or should it bolt straight to the bell housing ???
Speedo is easy get a d22 navara speedo sender, get navara cog off (die grinder with cut off blade) drill r33 gearbox cog out to suit navara Speedo sender shafts size. Slide r33 cog onto navara speedo sensor shaft and use some lock tite glue on it to be safe. Put navara speedo sensor in box ad make a new sensor bracket to hold it in
yeah ive read a few things now about doing it hope it is easy just hit the other issue few mins ago got new steering rack ends and thinking they would be the same as s13 buuuuutttt no to small do you know what sorta steering racks they have?
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
