Yeah but proven to bring boost on 500rpm in most applications I've even read somewhere boost come on nearly 1000rpm earlier. A mates mate had one for his 33 and he'd never seen a manifold that clean inside, the welds get ground smooth and polished almost, quality stuff really, and I guess the saying you get what you pay for shines here
yes very true ill look in to it a bit more i mean you want the best you really have to pay for the best i guess
on another note anyone seen one of these before come in a box of stuff with the car
good day today went up to mates to cut the section of engine bay i need to repair my laurels rusted bit out of his shell and found that his shell still has the clutch and break pedals and a manual dash cluster :) so good saved myself few $100
are yeah shit i was looking at that forgot about you umm i did see the fuse box i know there is a hole engine loom there but i cut it in half when i took the half of the car off but the rest is there i think message him and ask he would know whats there but there is defs a fuse box still mounted in side the car
well yesterday i sold the r32 thank god so now the manual gearbox will come and getting closer to doing the conversion spent today putting on the new steering rack boots and taking the aircon pump out (as it was left in there with just the pump and nothing else) still waiting on the manifold and other gaskets to come then put all that back on cant wait to drive it again even if it is auto
alright so im almost there with all my conversion parts ive got a question ive searched and havent been able to find the answer...
As im putting the 25 box on to the 25 motor what sort of sandwitch plate will i need to bolt up or should it bolt straight to the bell housing ???
Speedo is easy get a d22 navara speedo sender, get navara cog off (die grinder with cut off blade) drill r33 gearbox cog out to suit navara Speedo sender shafts size. Slide r33 cog onto navara speedo sensor shaft and use some lock tite glue on it to be safe. Put navara speedo sensor in box ad make a new sensor bracket to hold it in
yeah ive read a few things now about doing it hope it is easy just hit the other issue few mins ago got new steering rack ends and thinking they would be the same as s13 buuuuutttt no to small do you know what sorta steering racks they have?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
