Hey guys,
I have the sump that came with an engine I bought that I don't need.
It is an RB26 AWD sump modified with the Trust weld on extension. Welds are very nicely done.
It has also been modifed to allow bolting up the lower transmission mounts when using a 10mm sump adapter so should bolt straight up to the transmission when putting on an RB30. If not, you may need to re-drill the holes back in the original position.
The sump has had the baffles modifed with a welded in swirl chamber that should do a very good job of preventing oil surge.
The sump also has a -10 and -12 fitting in the side (bottom) of the sump that could be used for an external oil pump pick up or oil cooler pickup.
Sorry for no photos, forum was down last night when I went to load them. Will be loaded tonight.
The sump has no diff in it but I have a spare that I can supply (not installed) if needed for a bit of extra $$.
All sealant has been removed and it's all washed up ready to be bolted on.
Cheap price of $450 plus freight (I'm happy to box it all up for interstate transport) or I can deliver it within ~10kms of Melbourne CBD. Pick up from Hawthorn during business hours or Western suburbs after hours.
Cheers,
Ewan.
Hey Jamie,
Dennis (criko angel) has first dibs pending seeing some photos. I've promised him first right of refusal after seeing the photos.
I'll send him photos first, if he doesn't choose to take it then I'll load the photos and declare it still available.
Stay tuned!
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
