[Nsw] - White Evo 7 Stolen Plates Myswag, Merrylands Area
- Carbon fibre wrap - roof and rear wing blade
- HKS Kansai front lip
- Cusco powerbrace (painted in white)
- Side skirt ext & side spat
- Cusco full roll cage (in black)
- Front number plate contains "The-Lowdown.com" sticker
- Tow hook (colour is "purple" I believe)
- Contains CEO sticker @ the rear wind screen & rear passenger.
- Black Gramlight 57D with illesst sticker
Thanks for the comment guys.. I know it's a low possibility, but we need as much help as possible..
Edited by r3232r
CBD to West daily via M4/GWH. Will be doing a return run to Buxton late tonight. Hopefully spot it on the main roads
Though I'd imagine its been stripped already due to it being so unique. Keep an eye out on parts on gumtree.
Hope it is insured, these days crooks that steal those kinds of cars don't drive them around for long.. they end up stripped and put on forums/eBay etc.
Update from another forum
URGENT PLEASE HELP
THERE WAS A SIGHTING OF BLACK 300ZX WITH MY NUMBER PLATES (MYSWAG) SEEN DRIVING AROUND PARRAMATTA
Just
spoke with the police and they said next time if anyone sees my car or
my number plates to call the police straight away and they will send
cars in the area to the area and direct it was going. even if it looks
similar please call. If it is ok the owner of the car wont get in
trouble but please do you can call 000 or 131 444
  • 3 weeks later...
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
