Need some door cards for my track car. Currently have aluminium door cards which I got made up but I'm not really happy with (pictured below).
Any other ideas? Does anyone make prefab ones in FRP or carbon which aren't ridiculously expensive?
614574_10152113827405301_1159352651_o.jp
https://www.sau.com.au/forums/topic/420833-door-cards-on-a-race-car/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
