No, you can ignore what StevenCJR31 said, because it's not true.
bullshit. . ive got both motors side by side here and the intakes from the r32 rb25de and r32 rb20det DO NOT swap over they ARE different, dont go quoting shit
That's not what we're talking about. He is talking about putting an RB25DET head and inlet manifold onto an RB24S block. The block of the RB24S is the same as the RB25 block (except perhaps it has no oil squirters and possibly no hole for the knock sensor(s) ).
So your post was completely irrelevant, and it sounded like you were talking about RB24 that was based on stroked and bored RB20 stuff - which was NOT the topic of discussion. So I kindly invite you to back off.
absolutely nothing . . it was in answer to what roy said on this thread on 01/03 at 14:23 about the intake manifolds being VISUALLY the same on the na 25 and 20dets, i was mearly pointing out that whilst visually the same they are in fact different port size and stud pattern and therefore not interchangable, same top feed fuel injectors and fuel rail tho
I tell you what, we really need to fix the new forum software so quoting works properly again. I had to go over those posts 4 times to follow exactly who was saying what again.
I apologise for coming over like a dick. I should have said "not relevant" instead of "not true".
NA RB25 has no oil squirters either iirc, just the provisions for it. But having no hole for the knock sensor, would that be a problem?
I'll be getting the engine this week, thanks for the help guys.
Hole for the knock sensor could be gently drilled and tapped (give the example to follow on the other block). Worst case you do not install the knock sensor to the block. You just connect it to the wiring loom, wrap it in foam.bubble wrap and gaffer tape it to something solid. Or an even worse case, you don't connect it to the loom and you just put a resistor (there's a certain value you'd need, search it up) across the loom plug and the ECU won't know any different. Either of these leave you exposed to a little knock damage if your tune is a bit ragged or you get a gut full of bad fuel.....but that's no different to most people who are using aftermarket ECUs anyway, seeing as they don't usually use the knock sensor either.
    • The cross sectional area of a circular hole scales with the square of diameter. So a 2mm diameter hole is 4x the area of a 1mm hole. Not double. The 1.7mm hole is nearly 3x the area of a 1mm hole. You do not need restrictors at both ends of the oil supply line. If you have new, additional restrictors at the turbo end, that you did not have before, then you do not need a restrictor at the inlet end.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
